Capella_Ben's 80
- Capella_Ben
- My 4wd: Prado 150
Re: Capella_Ben's 80 [Recovered]
I now have HID in the high beam lights. Bit of stuffing around to get them in. Had to modify the retaining bracket a bit to make it fit. Also had to totally remove the passenger light to fit the new bulb. Then had to take it for a drive and adjust the levels. The lift seemed to put it all out quite a bit.
It's bloody good now!
- Capella_Ben
- My 4wd: Prado 150
On the weekend I changed over the coolant from the generic green to the Toyota Red. Took all morning as I had to chemically flush it and rinse it, etc. There was a bit of gunk in there (especially the overflow bottle). I was able to use some sand to really clean out the overflow bottle. I'm surprised at how well it came up.
Greg and I have been working on making some rock sliders. After a couple of weekends (2 days all up) we have finished the mounting brackets.
They were pretty difficult to make up as the chassis rails are angled along the side (narrowing towards the front) and the mounts also had to point down, so there were two angles to consider. By the end of the day we were also able to get one of the bain beams welded on joining the brackes together.
- maverick01
- My 4wd: 2005 Nissan Patrol 4.2tdi
Geez this Greg fellow must be pretty helpful
- Capella_Ben
- My 4wd: Prado 150
He's a good guy to know!maverick01 wrote:Geez this Greg fellow must be pretty helpful
- Capella_Ben
- My 4wd: Prado 150
Got hold of some rubber for the flares. Had a go at one.
Looking much better!
- Capella_Ben
- My 4wd: Prado 150
After much sanding stripping and de-rusting, I have re-painted my cargo barrier and installed it.
what an effort!
Now onto the draws....
what an effort!
- maverick01
Looks good and just need to finish if the steps now
- Capella_Ben
- My 4wd: Prado 150
Flash one mate!
Are you going to have a go at reconditioning your old alternator? It would be worth having a spare.
- Capella_Ben
- My 4wd: Prado 150
If I can find a rectifier diode pack for a good price I will. They are pretty hard to find, as it's almost cheaper to get a new alternator. It probably needs brushes as well, but they should be easier to find.
