maverick01 wrote:If your heading out into this kind of country then you would best be getting a tyre with a thick side wall or something along the lines of maybe say a 6ply rating or higher.
Although you may not be able to get them in say a 33 or similar but im sure you would be able to get them in your size Steve.
I know when i did the cape trip i used the old style goodyear wrangler mtr and had no issues with it apart from a blown tyre which was caused a split in the sidewall which happened and had been repaired in brisbane before we left.
I havent had any expereince with mickey thompson mtz but i have heard alot of good feed back about them used on shalley ground and held up well.
Capella_Ben wrote:You definitely need good quality tyres on the trailer for a trip like that. It is obviously best if you can use the same tyres as the hilux. Not sure if it is the same stud pattern though, that would be ideal. In an emergency you could interchange the tyres. Hey you could go old school and go split rims
Return to Mechanical and Accessories
Users browsing this forum: No registered users and 1 guest
